Surface from 3 curves
All  1-3  4-7
11439.4 In reply to 11439.1
Hi renklint, here's a method by dividing it up into small 4 sided elements and then applying sub-d smoothing.
11439.5
Or you can use for this kind of task FreeCAD, that has the ability to make surfaces from edges, in this case the curves you provided and other three to close the contour.
image Moi3Dt
image FreeCADt
To make it I've converted the curves in the Part Workbench into wire then I used those new to Make Face from edge, and it's done quickly but FreeCAD need a little effort to be used, in some cases can help.
Greetings
11439.6 In reply to 11439.3
赞同,moi应该加入相应的patch工具。network,nsided,loft,sweep对褶皱曲率的曲线都处理的不好。(Agree, moi should add the corresponding patch tool. The effect of network, nsided, loft, and sweep on the curve of wrinkled curvature is not as good.)
In this particular case
You can make also a big surface by a simple revolve... with a generator curve as you want
Then trim them... maybe more elegant and easy construction! ;)
Show messages: All  1-3  4-7
