Squircle script problems
All  1-3  4-7
11431.4 In reply to 11431.3
Hi Tom,
> There are several scripts, which one is the best to use ?
The one on the first message of the thread is working for me:
http://moi3d.com/forum/index.php?webtag=MOI&msg=5616.1
Attachment filename SuperEllipse.7z, command name SuperEllipse2D.
> ReferenceError: Can't find variable: LiteGraph
That one is a node editor extension. It needs to go inside the node editor folder and it would make a new node available inside the node editor.
11431.5 In reply to 11431.4
The Ssuperellipse script works fine !
The slider function is a nice enhancement, but why does
the slider-script only display half a circle ? Is there an
explanation how to use it correctly ?
11431.6 In reply to 11431.5
Hi Tom,
Brian mentions something about that here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=5616.9
It sounds like the slider version makes a half circle because it was for making profile curves for a 2 rail sweep with the endpoints on rail curves.
If you want to make a flat one and not one between 2 rail curves, probably use the SuperEllipse version instead.
11431.7 In reply to 11431.6
Thank you very much !
Show messages: All  1-3  4-7
