Squircle script problems
All  1  2-7
11431.2 In reply to 11431.1
Hi Tom, Brian's one from here is working for me:
http://moi3d.com/forum/index.php?webtag=MOI&msg=5616.1
What is the error message that you're seeing?
11431.3 In reply to 11431.2
There are several scripts, which one is the best to use ?
The one with slider works, but not sure how to use it as it displays only half of a squircle ?
For the others I get :
ReferenceError: Can't find variable: LiteGraph
squircle_t2.js line 150
146: factory.cancel();
147: this.setOutputData(0, output);
148: }
149:
150: >> LiteGraph.registerNodeType("Curves2/squircle_t2", squircle_t2);
151:
152: })();
11431.4 In reply to 11431.3
Hi Tom,
The one on the first message of the thread is working for me:
Attachment filename SuperEllipse.7z, command name SuperEllipse2D.
That one is a node editor extension. It needs to go inside the node editor folder and it would make a new node available inside the node editor.
11431.5 In reply to 11431.4
The Ssuperellipse script works fine !
The slider function is a nice enhancement, but why does
the slider-script only display half a circle ? Is there an
explanation how to use it correctly ?
11431.6 In reply to 11431.5
Hi Tom,
Brian mentions something about that here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=5616.9
It sounds like the slider version makes a half circle because it was for making profile curves for a 2 rail sweep with the endpoints on rail curves.
If you want to make a flat one and not one between 2 rail curves, probably use the SuperEllipse version instead.
11431.7 In reply to 11431.6
Thank you very much !
Show messages: All  1  2-7
