Grouping objects
All  1-8  9-15
<< Are the items then grouped together so they can be edited/moved as one unit and if so, how would I ungroup them?
You can all make just with the little menu and arborescence of the "Browser" when you have grouped somethings !
Select on the Browser or on the screen...
11428.10 In reply to 11428.6
Hi Gunter,
Open the browser by clicking "Browser" in the bottom right corner and then click on the 3 dots next to "Objects". A menu will drop down like this:
Clicking "Group" in the dropdown menu will cause a group containing the selected objects to appear in the Objects section of the Browser:
- Peer
EDITED: 16 Jun 2024 by PEER
11428.11 In reply to 11428.10
Hi Peer,
OMG, it was that simple, thank you so much!
I'm assuming this is available in V4?
Many thanks!
Gunter
11428.12 In reply to 11428.11
Hi Gunter,
No, grouping is new for V5, it is not available in V4.
11428.13 In reply to 11428.12
Great, thank you Michael!
Kindest,
Gunter
11428.14 In reply to 11428.1
hi gunter
在v4中我通常采用给对象共同命名的方式来实现分组,尽管整组一起选中只能在场景浏览器中完成,但是可以方便的进行重命名,并且不像用颜色那样眼花缭乱(In v4, I commonly group objects by assigning shared names. Although selecting the entire group is only possible in the scene browser, renaming is quite convenient, and it's less visually overwhelming than using colors.)
11428.15 In reply to 11428.14
Thanks for your help Suiyan
Show messages: All  1-8  9-15
