Grouping objects
All  1-4  5-15
11428.5 In reply to 11428.4
Thanks Pilou, ok that makes sense!
Many thanks!
Gunter
11428.6 In reply to 11428.5
Pilou, I downloaded V5 Beta and now I see this:
What do I need to enter as in the Key and Value fields?
Are the items then grouped together so they can be edited/moved as one unit and if so, how would I ungroup them?
Thank you for your help!
Gunter
EDITED: 15 Jul 2024 by GUNTER511
11428.7 In reply to 11428.6
EDITED: 10 Jun 2024 by PILOU
I believe that for you case you don't need of the "object user text"
The next v5 beta will have an additional channel of document and object user text available for scripts to store data attached to the .3dm file or to individual objects. Those will be stored as key/value pairs so that a script can use its own unique key name and not stomp on some other script's data as can happen using notes as a script data store.
<< Are the items then grouped together so they can be edited/moved as one unit and if so, how would I ungroup them?
You can all make just with the little menu and arborescence of the "Browser" when you have grouped somethings !
Select on the Browser or on the screen...
11428.10 In reply to 11428.6
Hi Gunter,
Open the browser by clicking "Browser" in the bottom right corner and then click on the 3 dots next to "Objects". A menu will drop down like this:
Clicking "Group" in the dropdown menu will cause a group containing the selected objects to appear in the Objects section of the Browser:
- Peer
EDITED: 16 Jun 2024 by PEER
11428.11 In reply to 11428.10
Hi Peer,
OMG, it was that simple, thank you so much!
I'm assuming this is available in V4?
Many thanks!
Gunter
11428.12 In reply to 11428.11
Hi Gunter,
No, grouping is new for V5, it is not available in V4.
11428.13 In reply to 11428.12
Great, thank you Michael!
Kindest,
Gunter
11428.14 In reply to 11428.1
hi gunter
在v4中我通常采用给对象共同命名的方式来实现分组,尽管整组一起选中只能在场景浏览器中完成,但是可以方便的进行重命名,并且不像用颜色那样眼花缭乱(In v4, I commonly group objects by assigning shared names. Although selecting the entire group is only possible in the scene browser, renaming is quite convenient, and it's less visually overwhelming than using colors.)
11428.15 In reply to 11428.14
Thanks for your help Suiyan
Show messages: All  1-4  5-15
