Scripting: Doing a scale and then rotate on the same object
All  1-4  5-6
11421.5 In reply to 11421.4
Hi Peer,
thanks for the clarification. So the .cancel() step could be left out when used in a command-script because there is a kind of final cleanup when the command ends. On the other hand it does not seem to hurt and would make the code reusable in a plugin/instant-script - or do you know of a caveat with this (other than bloated code - which of course might become a problem at some point)?
Achim
11421.6 In reply to 11421.5
I don't think calling .cancel() will cause any technical problem Achim.
- Peer
Show messages: All  1-4  5-6
