extras and plugins
All  1  2-7
11419.2 In reply to 11419.1
Quasi All scripts of Max Smirnov are here!
https://moi3d.com/wiki/MaxScriptArchive
All for make Subdivisions modeling inside Moi3D! ;)
sSPlit, SBridge, sSCale, SubDiv beta 9
and this fabulous thread! :)
http://moi3d.com/forum/index.php?webtag=MOI&msg=9689.1
About the"list" inside MOi3D it's Custom UI ;) (same archive Page above)
EDITED: 30 May 2024 by PILOU
11419.3 In reply to 11419.1
The extra icons are from Max's CustomUI mod, you can get it from CustomUI.2.0.beta2.zip from the archive link above.
Install instructions here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=6507.268
11419.4
great thanks,
i think i got the installed. i also found this
https://moi3d.com/forum/index.php?webtag=MOI&msg=7841.6
Size: 184.8 KB, Downloaded: 77 times, Dimensions: 1879x1011px
11419.5 In reply to 11419.4
The Extras button can also be added as a standalone thing without customUI:
https://moi3d.com/forum/index.php?webtag=MOI&msg=10353.1
11419.6
really cool :)
is there a way to have the new/added plugin icons appear in the right hand side menu instead of the bottom menu?
11419.7 In reply to 11419.6
Hi mike,
Currently it is set up to insert the new buttons into this containing element inside CommandBar.htm :
<span id="CommandBarCustomUI">
</span>
If you wanted to change it to insert it into the side pane you would need to edit the CustomUI .js files and the SidePane.htm file.
You would need to put in a target container element <span id="SidePaneCustomUI"></span> inside SidePane.htm and edit the CustomUI .js files to have this code:
moi.ui.commandBar.CommandBarCustomUI.insertAdjacentHTML(
Changed to this:
moi.ui.sidePane.SidePaneCustomUI.insertAdjacentHTML(
- MIchael
Show messages: All  1  2-7
