Joining and Filleting
All  1-2  3-6
11417.3 In reply to 11417.1
Hi Gunter, it looks like you solved this on the other piece in the same file, by constructing some additional pieces going downwards here:
Is there something about your previous solution that you don't like?
I'm not understanding right now why not just mirror the one you extended already?
11417.4 In reply to 11417.1
Hi Gunter, also there is a plugin that could help here which can extend surfaces:
http://moi3d.com/forum/index.php?webtag=MOI&msg=9747.7
I made the attached version by using that FlowExtendSrf plugin to lengthen the surfaces like this:
Using FlowExtendSrf:
After the surface extension, these 3 surfaces need to be retrimmed with these edges:
Then use Edit > Join to glue all the top object's surfaces together and then the top and bottom can be combined using Trim or also Boolean Union.
EDITED: 29 May 2024 by MICHAEL GIBSON
Forgotten this one! More effective and speedy indeed! :)
11417.6 In reply to 11417.4
Hey Michael and Pilou,
This is super helpful, thank you so much!
Much appreciated.
Gunter
Show messages: All  1-2  3-6
