Scripting the Trim command -- programmatically select objects to keep or remove?
All
1-7
8-9
mike (MVERHULST)
29 May 2024 (8 of 9)
11415.8
In reply to
11415.7
excellent,
thanks for your help :)
i needed to add
var objects = gd.getObjects();
objects.unlockSelection();
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Michael Gibson
30 May 2024 (9 of 9)
11415.9
In reply to
11415.8
Hi Mike, clearing selection lock is something that normally happens when a command ends.
When you run a startup script it's not using the "command" mechanism and so you'll have to do some things manually like that.
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Reply to All
All
1-7
8-9
