Viewport Screen goes black after Windows Lock Screen.
All  1-2  3-6
11413.3 In reply to 11413.2
Looks like manually defining the Graphics API=OpenGL might have worked.
I made the change and locked my windows session then reopened it and the viewport is still there.
I test a few more times just to make sure, but I think this solved the issue.
Prior to setting the API, I did try resizing and minimize and maximize window, moving from one monitor to the other and it didn't resolve the black viewport.
So I am glad I the manual setting is working. Was getting annoying having to restart moi every time I walk away from my computer for more than 5 minutes.
11413.4 In reply to 11413.3
I forgot to post yesterday as I got distracted with work, but unfortunately, manually setting the Graphics API isn't going to work. While it did resolve the black screen issue, it created another issue with selecting geometry. For some reason, it would only allow "click" selection in lower right viewport but not in the other three. Only marquee selection would work in the other three viewports. However If I maximize any view, then I'm no longer able to click select geometry in that lower right view. Considering that the black screen is a minor annoyance and doesn't impede my normal workflow, I'll guess I'll live with the auto for now. This is still using v4, I'll test v5 if there are issues when I get a chance.
11413.5 In reply to 11413.4
Hi KanakaRed, there is a fix in v5 for something similar to what you're describing so that might be fixed in v5.
2 things.
Did you try direct3d?
And there is a new driver this month…
Show messages: All  1-2  3-6
