Help with finishing curved radiused ramp transitions.
All  1-3  4-8
11407.4 In reply to 11407.3
Hi Guy, try with this version, I've simplified the edge structure here.
11407.5 In reply to 11407.4
Thank you Michael!
Can you give me a few quick hints on how you simplified the edge structure? I tried boolean union but it made no difference.
11407.6 In reply to 11407.5
Hi Guy, I deleted this current kind of patchwork of multiple surfaces:
So it looked like this:
Then I used Merge on the bottom edges so that there was just one edge down there:
Then Construct > Extrude which will now make just one larger surface going across the whole side-wall area:
Then Edit > Trim the large side-wall surface with the top edges:
Then Edit > Join to glue the pieces together.
11407.7 In reply to 11407.6
Thank you for the workflow help!!
11407.8 In reply to 11407.1
HI GuyLuke
我看了你的文件,并稍作尝试,将做的步骤用不同的线和名称作为注释 样式如图片并附加上制作文件,希望有所帮助(我不大懂英文,依靠机器翻译)
I have reviewed your file and made a slight attempt. I have used different lines and names as annotation styles for the steps, such as images, and attached the creation file. I hope it will be helpful (I don't understand English very well and rely on machine translation)
cam4.3dm为快速且模型为实体版本(图片soild.png)(Cam4.3dm is a fast and solid version of the model solid png))
It is also possible to separate face control points
EDITED: 19 May 2024 by SUIYAN
Size: 70.6 KB, Downloaded: 41 times, Dimensions: 374x387px
Size: 152.5 KB, Downloaded: 37 times, Dimensions: 1202x799px
Show messages: All  1-3  4-8
