Boolean
All  1-8  9-12
11406.9 In reply to 11406.7
Yours is also very good
Thank you very much PILOU
Message 11406.10 deleted 22 Sep 2024 by BOOLEANO
Message 11406.11 deleted 21 Sep 2024 by BOOLEANO
11406.12 In reply to 11406.11
Hi Booleano,
> Why can't I put the corners bent, so that they remain exactly the same, I have verified that they change
> depending on where you click on the last figure.
> Can it be obtained?
Try setting the "Stretch" option in the Flow command options:
This option is to control what to do when the base curve and target curve are not the same length.
The default mode for curve to curve flow is to travel along the target curve by the same distance along the curve (starting from the end closest to where you click), like this:
Stretch mode uses the entire length of the target curve:
Show messages: All  1-8  9-12
