Boolean
All  1-4  5-12
11406.5 In reply to 11406.3
Michael
Thanks for everything
Here is the process
You have to create a source curve and a target curve.
Source curve is on your object in the way you want bend
and target curve represents the target profile as you want the object will be bended.
You select your object
use Flow function
You select the source curve
You select the target curve
Done...
Phiro had a lunch more short than me! :)
Concept of the Flow method
EDITED: 14 May 2024 by PILOU
Message 11406.8 deleted 21 Sep 2024 by BOOLEANO
11406.9 In reply to 11406.7
Yours is also very good
Thank you very much PILOU
Message 11406.10 deleted 22 Sep 2024 by BOOLEANO
Message 11406.11 deleted 21 Sep 2024 by BOOLEANO
11406.12 In reply to 11406.11
Hi Booleano,
> Why can't I put the corners bent, so that they remain exactly the same, I have verified that they change
> depending on where you click on the last figure.
> Can it be obtained?
Try setting the "Stretch" option in the Flow command options:
This option is to control what to do when the base curve and target curve are not the same length.
The default mode for curve to curve flow is to travel along the target curve by the same distance along the curve (starting from the end closest to where you click), like this:
Stretch mode uses the entire length of the target curve:
Show messages: All  1-4  5-12
