MoI+Blender workflow
All  1-2  3-20
11405.3 In reply to 11405.2
Thanks for the nice words MO!
It's my turn to thank you for the fantastic Rebuild Surface script :) It's a real game-changer for MoI, and in fact I'm about to ignore my own advice and rely on it to get my next car made entirely within MoI. I need to get the hang of it to get predictable results, but it's a dream come true!
11405.4 In reply to 11405.3
Thanks kindly for the informative information. Truly appreciate it.
11405.5 In reply to 11405.4
Thanks for the kind words KENMO. Another fellow user messaged me and asked me to do a tutorial of doing a car panel with this workflow. I don't see how this can be useful as I'm just doing standard things in both programs, and, to be honest, I'm not even good at them. But anyways, here's a sped-up video of doing a car hood.
Sorry for the lack of speech, I'm not a native speaker but I think it's obvious what I'm doing. Also sorry but the capture software decided to glitch when I was recording Blender:
11405.6 In reply to 11405.5
Sorry but I do not see the video you are referencing.
11405.7 In reply to 11405.6
That's weird. I can see it embedded in the post on my end. You might have some caching issue or if everyone can't see it I guess it could be a forum issue?
Anyways, here's the link:
https://www.youtube.com/watch?v=l3yIqCT9I18
11405.8
Nice work on the Car immortalx and the Moi/blender workflow is a really good way to tackle car modelling. Thanks for sharing your technique.
One technique you might want to try in the future is output your Moi model to a dense mesh and retopo in blender with shrinkwrap modifier.
The shrinkwrap modifier would go below a 2 level subd modifier. CG Masters use this technique on their car models however they use blender to create the guide mesh instead of MoI.
https://cgmasters.com/3d-cars-inside-and-out-in-blender/
~Kevin~
11405.9 In reply to 11405.8
Thanks for the tip kevjon, I'll definitely explore this option. Although I enjoy more to do things in MoI instead of Blender tbh! Some things in Blender feel really weird like the choice of shortcuts :p
11405.10 In reply to 11405.7
Now I am totally confused. I thought you were using MOI3D! Sorry but that app does not look like MOI3D to me, Is it Rhino or some other app?
EDITED - After reading another post here I see you are using a customized UI for MOI3D which I never knew existed. Sorry about that.
EDITED: 20 May 2024 by KENMO
11405.11 In reply to 11405.10
I enjoyed watching this video and fully understood your Blender segment, but I could not follow the MOI3D part as I use the standard MOI3D interface. I think adding an audio narrative would make it much more easier to follow since you are not using the standard MOI interface. Thanks kindly for the video. I enjoyed it but did not learn much on MOI3D.
I use the commercial Blender add-on Quad Remesher ( https://exoside.com/ ) for auto retopology of my photogrammetry models via 3DF Zephyr ( http://www.3dflow.net/ ) and on some of my 3D Coat sculpted models. I find in some instances it works much better then 3D Coats own auto retopology command.
Again many thanks...
11405.12 In reply to 11405.11
Hi KENMO, sorry for the lack of audio. I made this in a rush for another forum member.
I'll gladly answer any question you have but I'm not doing anything particularly intricate. I'm laying down freeform-curves, move their points around until they follow the lines in the blueprints, and when 4 of them form a quad shaped-area, I select them and use the Network command to generate a surface. In a later part of the video I use some curves to trim the lower-right part of the main surface (where the headlight is located) and delete it. I then use another curve to define the shape of the dip in the hood. I trim the surface with that curve, and that effectively splits it into 2 parts. I toggle the points of the left one to on, and then move them a bit down. Finally (at the 4:00 minute mark), I select the edges of the 2 surfaces and use the Blend command. That's all there is to it.
11405.13 In reply to 11405.12
Thanks very much. That certainly clears things up very much. Again thanks for your reply and kindness.
11405.14
Am I correct in stating you create our base mesh in MOI3D then retopo and add details in Blender?
This seems the opposite of Michael suggesting to create the base mesh in Blender then import into MOI to add details.
Your workflow seems to be more inline with the folks who model model cars and car parts for 3D printing.
Again, many thanks...
11405.15 In reply to 11405.14
That's correct KENMO. I guess it works both ways but I prefer the MoI->Blender path for a couple of reasons:
- I like having the final mesh in Blender where I can experiment with materials and get it ready for rendering.
- It's easier to construct large curvy surfaces in MoI following the blueprints with reasonable accuracy. In Blender you have to account for the movement and "shrinkage" of vertices when you turn on the subdivision modifier.
- The lack of materials and complex lighting in MoI, sometimes makes it difficult to judge if you're correctly modelling a shape. In Blender you can do a quick render and compare with reference photos, and then make adjustments.
- Since I model only half of the model, Blender helps with that by having better mirroring functionality which you can turn on/off anytime.
- Some final tweaks are simpler to do with polygonal modelling where you can just drag some vertices around.
Hope that helps. I also just finished another car with the same workflow. It didn't turn out that great (and I forgot to model the mirrors
11405.16 In reply to 11405.15
I was also told Blender is great for concepting but when it comes to actual manufacturing or making a physical product it lacks accuracy for realism which is required in scale model building in 1/32, 1/24, 1/25, 1/16. 1/18, ... scale. I am told apps like Rhino, Form-Z, have the required accuracy.
I was quite despondent by Michael's reply and instance that I should be using Blender which was contrary to what many who create aftermarket parts for scale model cars and quite confused.
I am pleased by your original post and agreement with what others who create parts for scale model cars have told me.
Again many thanks for your reply.
11405.17
Here is a fender I modeled in MOI3D as per a tutorial here by Ed Ferguson.
I then import the fender into Blender where I retopo it.
Exported from MOI3D as an obj and imported into Blender. Not the quad/tri count is 14,312. A bit too high for my liking.
I use the commercial plugin Quad Remesher for auto retopo after setting the target quad count. Below is the result with 2531 quads/tris
The only issue I have is with the actual car bodies. I still can not get the hang of it. But for car parts like fenders, wheel rims, I beam or tubular front axles like those used in classic pickup trucks, model As, hot rods and gassers, MOI3D is much better than Blender. I also find MOI3D is much easier and faster to create these parts. I am considering on attempting to model a detailed engine block like a small block Chevy V8, classic Hemi or Flat Head Ford (already created one started in Hexagon3D and finished with Blender but I lacks true scale and dimensions.
11405.18
I did attempt several times to voxel sculpt a car body in 3D Coat but I find 3D Coat hard to get good dimensions and scale. And 3D Coats auto retopo is hit or miss for me. Blender's Quad Remesher is much easier and I find I get much better results then 3DC auto retopo. I have manually retopo'd in 3DC but find the manual retopo process is much longer and more tedious then modelling the original source object.
11405.19
Sorry for the late reply KENMO, I don't get notifications on subscribed threads so it's easy to miss replies!
Thanks for sharing your process, yeah quad remesher looks like magic!
11405.20 In reply to 11405.19
And worth the money. I find it much simpler to use and most times, achieves better results then 3DCoat's auto retopo.
Show messages: All  1-2  3-20
