Command Palettes?
All  1-2  3-9
11400.3 In reply to 11400.2
Thanks Michael. That's certainly a step in the right direction. It would be nice if you could set the default of which palettes were open without the htm editing, though I might try that some day. Is there any way to eliminate the wasted space at the top of that section? I don't think I've ever seen anything there, and it would give more room for palettes.
Rusty
11400.4 In reply to 11400.3
Hi Rusty,
It's possible to do this in the startup script. Which ones do you want to be open by default?
There's actually a lot of stuff that goes there, when you run a command the options for the command are shown in that area:
And if you're not running a command but have an object selected the object properties go there:
Since there is stuff being shown there all the time it keeps some space there reserved so the palettes don't jump around as much.
You have also the solution to put all things in a floating palette! ;)
https://moi3d.com/forum/index.php?webtag=MOI&msg=9758.1
11400.6
OK, I clearly wasn't thinking when I said that empty space wasn't used :-) I guess I assumed those property boxes were separate and not something that needed reserved space.
I'll attach the best default view I can come up with for the space I have. I'd love to get Dim in there too, but there isn't room. I could stand to lose SubD completely since I don't think it's anything I'd ever use. What I should probably do is figure out how to edit the htm file. I find the icons for each tool plenty big, and I'd even be fine with making them all smaller to fit more on. I'm doubt that's as easy as it sounds.
Overall, I like having the tools in a fixed position rather than a floating menu, but that might just be me. Appreciate the thought though.
Thanks!
Rusty
EDITED: 2 May 2024 by 13BRV3
Size: 109.9 KB, Downloaded: 95 times, Dimensions: 282x1317px
11400.7 In reply to 11400.6
When you have several screens, (latop, monitor...) that can be useful! ;)
11400.8 In reply to 11400.6
Hi Rusty, please try putting this version in the startup folder and take away the other one.
This one should close the Select, SubD, and Dim tabs like you show above.
11400.9 In reply to 11400.8
That works perfectly. Thanks for customization!
Rusty
Show messages: All  1-2  3-9
