Hot keys
 1-11  12-23
1139.12 In reply to 1139.10
Yes Control+O is O.K
1139.13 In reply to 1139.11
>>> No the files that you indicate commands directory Why?
Hi Juan,
Just see my post above : http://moi3d.com/forum/index.php?webtag=MOI&msg=1139.5
If your shortcut "ALT+K" is for the "ConstructionLine" command, then you must install the script in your "Commands" folder. It is not a script that automatically installs with MoI.
That script works fine here...
EDITED: 20 Nov 2007 by SCHBEURD
1139.14 In reply to 1139.13
Hi Juan, I think that Schbeurd has figured out the problem.
You likely installed some custom commands for the previous beta, these went into the \commands sub-folder.
You need to copy these over to the new beta's \commands folder for them to run in the new beta.
1139.15 In reply to 1139.5
Schbeurd wrote:
> @ Michael : this can be quite confusing for some users I think. Would it be
> possible to enclose all these scripts in the "standard" version of MoI ?
Well, there's always new ones kind of coming along...
For 2.0 betas I'll figure out a better solution - I think maybe a separate centralized \plug-ins folder (probably in the same location as the moi.ini file) would work well so that extras can be installed in one place and still used by new beta releases without any extra copying around, just like the moi.ini file.
1139.16 In reply to 1139.15
That would be a good solution I think. But maybe some of the most useful or "popular" commands should become an integral part of MoI interface (accessible from their own Icon in the main window). I tend to forget that some of them exist (like "ShrinkTrimmedSrf") if they are just accessible through shortcuts... ;-)))
1139.17
Hi Michael:
The problem solves copying and paste the commands of the previous beta in the new.
Thanks for their attention
Juan Galvan
1139.18 In reply to 1139.17
Hi Juan, that's great!
1139.19 In reply to 1139.16
Hi Bernard,
Yeah, I just need to find kind of a tidy place to put them.
Like ShrinkTrimmedSrf for instance can be useful in the right circumstance, but on the other hand quite a lot of people will never need to use it. So I don't really want to place it at the same level as more frequently used things.
I'll be working on finding a place in the UI to stash some of these types of things.
Also for extra plug-ins I'm thinking of having a "Plug-ins" icon down on the bottom toolbar, I was thinking to the left of Options. That would bring up a text menu with all the available custom/extra plug-ins in it so that would be an easier way to browse through them visually instead of remembering keyboard shortcuts.
1139.20 In reply to 1139.19
I am hoping you will add "Incremental Save" as an alternative in the Save Icon on the desktop---please!
1139.21 In reply to 1139.20
Hi Brian, it is kind of tough to add too many things across there because it is a pretty tight fit on a 1024x768 screen.
But it is possible to edit the UI and add that button in there now if you want.
The file that controls that bottom toolbar UI is here:
C:\Program Files\MoI beta Nov-18-2007\ui\CommandBar.htm
You can edit that file with notepad to add buttons to the UI.
I've attached an edited version here that adds an "Inc" button next to Save, to do an incremental save. Unzip it, and copy this new CommandBar.htm over top of the old in in that \ui folder.
You'll need to repeat this in future installs though, so you may want to keep a note of this procedure.
1139.22
Hi, all
Thought I'd throw in my 2 cents,
I've been using an added tab for extra command buttons at the bottom of the side pane for a few months, so I thought I'd throw this out there, maybe someone will find it useful --
Instructions and files to set it up are in the zip. Hope this helps!
Paul
1139.23
Thanks Michael/Paul. I hope I can work out howto!---more learning..............
Show messages:  1-11  12-23
