STEP export
All  1  2-3
11386.2 In reply to 11386.1
Hi Don, what are you using to make the file, is it "File > Save As" or "File > Export" ?
The difference between these is that "File > Export" writes only the selected objects to the output file, while "File > Save As" will write everything regardless of selection.
So what you describe would be normal behavior if you had only the text objects selected and did a File > Export.
Please let me know if that doesn't explain it.
11386.3 In reply to 11386.2
I had a defect in my file. It was not a full solid. I am sorry to have taken your valuable time for a dumbbell issue. My lesson is, don't report a bug when you are sick and exhausted, but keep working anyway.
Now that I am actually awake, I have a file that is working fine. Thank you so much for MOI.
Don
Show messages: All  1  2-3
