utf-8 problem in language string
All  1  2-4
11373.2 In reply to 11373.1
Hi Moi3dFan, what is the text encoding for your English_NoText_RuHelpStrings.txt file?
Is it saved in a Unicode format (like UTF-8 or UTF-16) with "Byte Order Mark"? If not then try that.
If that doesn't help please post the English_NoText_RuHelpStrings.txt file so I can reproduce what you show over here.
11373.3 In reply to 11373.1
If a LanguageStrings.txt file has no byte order mark on it, it will assume that it's text in Windows-1252 format.
To avoid it from being processed as Windows-1252 format text, make sure the .txt file is saved in UTF-8 or UTF-16 format, with BOM (Byte Order Mark) set on it.
11373.4 In reply to 11373.3
Oh, great! It worked!
Thanks so much
Show messages: All  1  2-4
