show hidden curves
All  1-3  4-11
11370.4 In reply to 11370.2
Hi Phiro,
Yes I've tried checking that box, but I only see hidden edges. I don't see curves that aren't part of a surface. Weirdly it did show hidden curves in one case, but I haven't been able to get it to do that again.
If you draw a curve behind a solid and check "Display hidden lines" do you see the curve as a dashed line? Right now I only see the curve if I mouse over it and then it's highlighted instead of dashed.
- Peer
11370.5 In reply to 11370.3
Guess we were typing at the same time. See my reply to Phiro. I don't see hidden curves when I check that box; only edges.
- Peer
11370.6 In reply to 11370.4
Hi Peer, yes when that's set then a solid and a standalone curve like this:
Should look like this when the curve is behind the solid:
Strange Peer.
I see the curves behind objects as in this screenshot.
11370.8 In reply to 11370.7
Thank you both for the screenshots!
I poked around and it looks like if a standalone curve is in the same group as the occluding surface then "Display hidden lines" has no effect.
- Peer
11370.9 In reply to 11370.8
Hi Peer, yup that's a bug, I'll take a look.
11370.10 In reply to 11370.8
Hi Peer, I'll have this fixed for the next v5 beta. A workaround currently is that the bug won't be triggered if you have at least one surface or solid object in the model that is not in a group.
Thanks, - Michael
11370.11 In reply to 11370.10
Thanks, Michael, for the workaround!
- Peer
Show messages: All  1-3  4-11
