show hidden curves
All  1  2-11
Is this option you searched ?
11370.3 In reply to 11370.1
Hi Peer, you can have both hidden curves and edges drawn in fainter dotted style using the option Phiro shows above but sorry there is not any way to do it for only standalone curves or only edge curves separately.
11370.4 In reply to 11370.2
Hi Phiro,
Yes I've tried checking that box, but I only see hidden edges. I don't see curves that aren't part of a surface. Weirdly it did show hidden curves in one case, but I haven't been able to get it to do that again.
If you draw a curve behind a solid and check "Display hidden lines" do you see the curve as a dashed line? Right now I only see the curve if I mouse over it and then it's highlighted instead of dashed.
- Peer
11370.5 In reply to 11370.3
Guess we were typing at the same time. See my reply to Phiro. I don't see hidden curves when I check that box; only edges.
- Peer
11370.6 In reply to 11370.4
Hi Peer, yes when that's set then a solid and a standalone curve like this:
Should look like this when the curve is behind the solid:
Strange Peer.
I see the curves behind objects as in this screenshot.
11370.8 In reply to 11370.7
Thank you both for the screenshots!
I poked around and it looks like if a standalone curve is in the same group as the occluding surface then "Display hidden lines" has no effect.
- Peer
11370.9 In reply to 11370.8
Hi Peer, yup that's a bug, I'll take a look.
11370.10 In reply to 11370.8
Hi Peer, I'll have this fixed for the next v5 beta. A workaround currently is that the bug won't be triggered if you have at least one surface or solid object in the model that is not in a group.
Thanks, - Michael
11370.11 In reply to 11370.10
Thanks, Michael, for the workaround!
- Peer
Show messages: All  1  2-11
