Update the components
All  1-10  11-13
11367.11 In reply to 11367.10
I am working in version 5, the file that significantly slows down I sent to your email
11367.12 In reply to 11367.11
Did you try turning off all object snaps to see if navigating the viewport speeds up? The reason I ask is because I've noticed that things can get pretty sluggish if there are a lot of curves and I use something to control the viewports other than the pan/zoom/rotate buttons. Like using a SpaceMouse creates this problem. I think it's because the pan/zoom/rotate buttons temporarily disable calculation of object snaps by the CPU, but navigating with a SpaceMouse doesn't.
So, if you're not using the pan/zoom/rotate buttons you might try using them instead, or try manually turning off object snaps to see if it's the object snap calculation part that's slowing things down.
- Peer
11367.13 In reply to 11367.12
Another thing which you might want to turn off in moi.ini for heavier files is:
[Drawing Aids]
ObjectSnapShowMarkers=n
That will disable the little "x" marks that show the available snaps around the mouse cursor. If you are working zoomed out on a heavy file there can be quite a lot of these getting drawn and it also needs to compute their visibility if View > "Display hidden lines" is off.
Show messages: All  1-10  11-13
