Increment numbers on circular array
 1-13  14-23
11357.14 In reply to 11357.13
This looks excellent.
I wonder if there is any tiny distortion in the numbers?
11357.15 In reply to 11357.14
"I wonder if there is any tiny distortion in the numbers?"
Not if you check Rigid in the Flow command. In this case even without using Rigid the distortion is minor.
11357.16
flow works ok in nodeditor.
Barry
Updated:
Tidied up into a Macro allowing text rotation and easier to understand.
Update 2
New Nod File Clock Dial 2m
Modified again to speedup dial rotation.
EDITED: 5 Mar 2024 by BARRY-H
11357.17 In reply to 11357.16
Thank you guys - most impressive response and (very) helpful. Suspect I am going to have to spend some time climbing a very steep learning curve!
This software is awesome in its power, but as Frenchy says you do need daily training!!
In particular thank you Barry for the .nod file. It looks like it does what I want - just have to work out what all the knobs and sliders do !!
EDITED: 5 Mar 2024 by WISTY
11357.18 In reply to 11357.16
Hi Barry,
Excellent work on the node editor! Can the node be modified for text rotation? I made this perpetual calendar. The Cad/Cam software being used was difficult to get it right.
Thank you,
Wayne
EDITED: 5 Mar 2024 by WAYNEHILL5202
11357.19 In reply to 11357.18
Hi Wayne,
see update have tidied up the nod into a Macro so text & dial rotation for alignment are adjustable.
Barry
11357.20 In reply to 11357.18
Nice result Wayne! Really like your design.
11357.21 In reply to 11357.16
Hi Barry-H,
Thanks for sharing your Node.
But I've got a quick question for you:
How to change the starting number? for example how to change it to 1 instead of 0?
Best,
Psygorn
11357.22 In reply to 11357.21
Hi Psygorn,
open the macro and find the progression node and set the base to 1 instead of 0.
Barry
11357.23 In reply to 11357.22
Tanx! :-)
Show messages:  1-13  14-23
