Specific model and general milling preparation questions ?
All  1  2-12
11353.2 In reply to 11353.1
Hi Sven, so typically the main thing that shop will likely be looking for is to have the model be a closed solid object.
Usually to fill in the triangular area you show you would use Construct > Planar. But this case here is having some problem with that so instead you can use Draw solid > Plane to put in a rectangular plane and then use the Edit > Trim command to cut the plane.
11353.3 In reply to 11353.1
Hi Sven, is the attached version what you're looking for?
11353.4 In reply to 11353.1
Hi Sven, so for how to do it - booleans can have difficulty when there is a lot of overlapping coincident surface areas like you have here.
So I didn't use booleans in this case, I used Edit > Separate to break things into individual surfaces, deleted interior pieces and used Extrude and Trim to cut several pieces along their own seam curves, like this:
11353.5 In reply to 11353.1
Hi Sven,
The most important thing to give a shop is a good 2D drawing with dimensions, tolerances, material, and surface finish all spelled out. A machinist can't tell from a 3D model what your intent actually is. It's not possible for them to machine the ideal "platonic" version of your model, so they need to know how much they're allowed to deviate on each feature.
That said, some shops will accept just a 3D model, an overall tolerance, and an overall surface roughness. But if there's no drawing and you don't like what they deliver it will be difficult to get them to fix it.
Re:
> high-density polyethylene
As you might have found, that's a difficult material to mill. In some ways worse than the hardest steels because it requires razor sharp tools and gentle clamping since it's both soft and tough.
I would try to find a very small (1 man) shop that's close enough to you that you can go there and talk it over with them in person. That way they can give you feedback on the design and you can fully describe what the important areas of the part are.
Finding a good machine shop can be pretty difficult.
Re:
> I appreciate when people create posts with animated gifs
> showing what they are looking for or before and after.
LICEcap is a good program for Mac. Not sure about what's out there for Windows.
- Peer
11353.6
Yes, exactly Michael. Thank you for explanation and video which makes sense.
Thank you Peer. Good sounding practical advice. I'll try LICEcap.
Sven
11353.7 In reply to 11353.4
As a follow-up to this technique I've attached a simplification because although I could create planar on one side after following your technique Michael as I was unable to reproduce on the other side. A mirror does work, but planar or the following technique does not. I extruded a line vertically from a magenta curve on one side and a cyan curve on the other. The magenta curve can be boolean diffed or trimmed with the "curiosity" object without issue while cyan curve cannot do either. I'm unable to see any difference between the two sides and reproduced in a symmetrical manner so I'm stumped ?
Furthermore when viewing from left side I should see cyan curve and from right side magenta curve, but I see magenta from both sides.
Sven
11353.8 In reply to 11353.7
Hi Sven,
I'm sorry I'm not understanding this part.
Is this the curiosity object here? :
And the magenta curve is this one?
I'm not understanding how you would boolean those together, if a plane is extruded from the magenta curve upwards, it just barely grazes the end of the curiosity object and does not divide it into pieces:
11353.9 In reply to 11353.8
Hi Michael, I assumed too much...
so in this image I can successfully boolean diff the blue object from the magenta base object ( trim works equally well ) resulting in...
but when I try the same thing with cyan curve ( either boolean or trim ) it doesn't work. I've tried recreating ensuring symmetry so I'm not sure what I'm doing wrong...
lastly, I notice that viewing from the right results in same image as viewing from the left, but should I see cyan and not magenta line from the right ?
right view
left view
11353.10 In reply to 11353.9
I hope the next model help you
11353.11 In reply to 11353.9
Hi Sven, ok thanks I think I understand better now.
Surfaces that barely graze each other and are also tangent can tend to be more difficult in surface/surface intersection calculations.
It will be easier for Trim to work on your cyan plane if you select the edges as the cutting objects rather than the full object, like this:
Then it should be cut up ok:
Also another way you can do it is to draw in 2 connecting lines like this:
Then select the lines and edges like this:
And then Construct > Planar can make a trimmed plane there:
11353.12
Thanks for explanation Michael. I realize that there are other solutions, just figured I had to be doing something wrong given the symmetry of model and it working one side, but not the other.
Thanks for the models vic.
Sven
Show messages: All  1  2-12
