How to Create a Solid from a Distorted Curve?
All  1-13  14-15
11352.14 In reply to 11352.13
Hi MarzRX,
Yes, naked edges. I have it shortcuted so you didnt see me type it. Definitely a go to for “why not a solid”
Boolean vs Join
The way i would view it is boolean for solids, join for surfaces (that are edge to edge) if surfaces overlap in the middle somewhere, you would want to “trim” first.
Boolean is actually trim-join-remove rolled into one. So it “CAN” give results with surfaces, but just not the habit to create.
11352.15
BurrMan, thank you. When dealing with surfaces, I'll first try joining with "Edit | Join".
Thanks to everyone's help, I was able to create the model. Thank you.
It's not quite the shape I wanted yet, but I've learned a lot in the process.
marzRX
Show messages: All  1-13  14-15
