How to align 4 photo references
 1-11  12-31  32-39
11350.32
My desire is to be able to create models like this in MOI3D with the intent to 3D print them and then detail them using parts from 1/24 / 1/25 scale car model kits (made by AMT, Revell, Monogram, MPC, JoHan, etc).
Supped up Ford Flathead V8 to be used to power an American hot rod. Modeled in Hexagon. I did not use any blueprints or reference image. I used a 1/8 diecast model I own of a stock flat head then added the super charger and tri-carbs which I modeled from reference images.
I hope this gives you an indication of what I am trying to accomplish in MOI3D. I think the engine, chassis/frame, suspension parts, etc would be easy. It is the body that has me stymied.
EDITED: 25 Feb 2024 by KENMO
Size: 286.2 KB, Downloaded: 63 times, Dimensions: 2207x1327px
Size: 316.4 KB, Downloaded: 42 times, Dimensions: 2484x1327px
11350.33 In reply to 11350.29
Sorry little misunderstanding! ;)
must be reading
The AI have only been in existence for 6 months! Not me! :)
Else you can try tones of renders, Refines! ;) (+ enter Images)
EDITED: 25 Feb 2024 by PILOU
11350.35 In reply to 11350.34
Nice additions. However AI is not for me. I do like the AI in Adobe Photoshop (Firefly?) but all other AI does not appeal to me.
11350.36 In reply to 11350.32
Hi Ken,
> has me stymied.
Yes, car bodies are difficult shapes to model.
They tend to be a more organic type of form and need a fairly different strategy than mechanical parts. It's a type of modeling that has a much steeper learning curve to it.
It seems like you need a pretty high level of guidance which is just not currently available for MoI, like step-by-step tutorials with voice.
Probably your best bet for success would be to create the body in one of your poly modeling programs and bring it in to MoI with the sub-d converter and then do other parts with MoI.
11350.37 In reply to 11350.36
Michael,
The images I've uploaded where ALL modeled by ME, including the flathead V8 engine.
ALL were created from scratch. NO kit bashing.
ALL were modeled in polygonal apps Hexagon 3D and Silo by ME.
I realize how hard cars are to model as I've fought and won that learning curve.
Here is a futuristic hot rod I modeled from scratch. Again no kit bashing.
And later textured and rendered in e-onsoftware's Vue Creator.
I simply believe cars can be modeled in MOI3D. To suggest I purchase Rhino or Solidworks is SILLY. To suggest I continue to use a polygonal app is SILLY. When I have given reason why I want to use MOI3D for accuracy to scale (1/24 or 1/25) for 3D printing.
11350.38 In reply to 11350.37
Hi Ken, so I guess the part I don't understand is that you were previously saying you are not able to model cars in Moi because you could not find adequate tutorials to help you learn how to do it.
Did I misunderstand that part?
That's not something that is easy for me to remedy, making tutorials that go over everything for advanced modeling in heavy detail and with voice are very difficult and time consuming to produce.
What I'm trying to tell you is pretty straightforward - you have said you need detailed tutorials, MoI does not have those tutorials and so MoI does not meet your requirements.
If you're already proficient in doing the car bodies in Hexagon and Silo then it would seem to make sense to continue to do so and bring them into MoI using the sub-d conversion.
I think you've been given some bad or oversimplified advice on this point.
If your car body doesn't have any stuff like exact circular holes cut in it then what type of accuracy problems are you trying to solve?
You have to convert it to polygons at the end to send to the 3D printer anyway.
If you have organic swoopy surfaces as NURBS with no circles, lines, and arcs anywhere in the shape why do you consider that to be more accurate?
The "better accuracy" of NURBS modeling is generally for stuff like you have precise spheres, cylinders, circular holes and things like that in mechanical parts which are not present in organic shapes (like car bodies).
11350.39 In reply to 11350.38
It is the advice of people who are actually creating plastic scale car models and plastic car model parts.
Sorry Michael, but I will take their advice over yours unless you are also modeling model car parts as well.
I am done asking questions on this topic here.
Show messages:  1-11  12-31  32-39
