General menu versus Dimensions menu
All  1  2-3
11349.2 In reply to 11349.1
> is not separated by the faint lines. Since the 4 settings are related, it might be
> nice to format them similarly to the Dimensions method???
Yes that seems like a good idea, it is nice to break apart related areas when possible.
If you want to see what it will look like you can update your v5 beta's GeneralOptions.htm file in the ui folder with the attached version.
> Previously placed dimensions do not change their display format, in the event the master
> formatting is changed, which is OK, IMHO. (AFAIK)
Yes, that's how it is intended to work currently at least. The properties you set in Options > Dimensions are "Property presets", meaning they will be used as the initial properties assigned to a dimension when it is created. Once a dimension has been created it has its own property values which can be changed by selecting it and using the "Details..." object property dialog.
Once a dimension has been created there isn't any further connection between it and the preset.
Maybe in the future something could be added for that though, like maybe at least some method in Options > Dimensions to select dims that match that preset.
11349.3 In reply to 11349.2
Cool!
Show messages: All  1  2-3
