Wireframe generator?
All  1  2-10
11345.2 In reply to 11345.1
Hi Matadem, you can generate wire sections of a model in MoI like you show by drawing in lines and then using the Construct > Curve > Project command to project the lines onto the object:
11345.3
Organic form created in blender - retopology into QUAD MESH then import SUBD with workflow as demonstrated by Michael, works great on just about any shape. Rebuild curves after running sections to get simpler cleaner curve info.
11345.4
Got it!
Moi again fast and efficient :D
to Alexpolo ...where can I download the model that you pictured if available?
I am also looking for something like this https://www.instructables.com/Laser-Cut-3D-Models/
but 123d make is no longer available...I think.
And I think Rhino has something similar.
Can Moi do this? or any other small app?
Thank you!
11345.5 In reply to 11345.4
“”””” I am also looking for something like this https://www.instructables.com/Laser-Cut-3D-Models/
Can Moi do this? or any other small app?””””””””””
You can get That type of output from 3d printer software.
Just slices up your model and can spit out the different profile levels.
A bunch of free ones that are quality. Someone here can probably recommend one.
11345.6 In reply to 11345.4
Hi Matadem,
I think that function from 123D is now a slicer app in Fusion360 so you might look there.
Also some other possibilities in this reddit thread:
https://www.reddit.com/r/Fusion360/comments/q3y3pm/does_anyone_know_of_a_good_alternative_to_slicer/
You might look at the Blender add-in that is mentioned there.
Normally you have a powerful slicer V6 free by TIG for SketchUp
In free you must first find the free SketchUp Make 2017 somewhere
it's the last free version of SketchUp with you can use the Plugins!
https://sketchucation.com/plugin/781-tig_slicer
EDITED: 12 Feb 2024 by PILOU
11345.8 In reply to 11345.4
Autodesk 123D is still available:
https://autodesk-123d-design.en.lo4d.com/windows
best regards
Ken
11345.10
Yes I got the 123D works fast...as much I as do not like sketchup the slicer looks great!
Tnx!
Show messages: All  1  2-10
