Point Offset Script request
All  1-9  10-16
11342.10 In reply to 11342.9
It works even better than intended! Thank you!
There are a couple things that could be improved:
- Points in "Make Point" mode are added to the polyline itself. You can made checkbox for this mode.
Of course, I can cut the curve by these points and then connect them, but I want a shortcut.
- Note that, in "Make curve" mode. If a polyline has only one point selected, then after applying the script the whole polyline turns into a curve. This is rather wrong, for I want to smooth out one point.
I have a solution though - I'll just detach the corner I want and apply the script.
Thank you for taking the time to do this, with scripts like this you make it very easy to work in your favorite program
11342.11 In reply to 11342.10
Hi Moi3dFan, you're welcome I'm glad that is useful.
I've updated the script (attached in message above) to have an additional polyline mode where it generates a polyline with the new points in it.
I've also updated it so that it will only smooth selected points and leave unselected ones as sharp corners.
And seems working even Polylines are not planar!
And multiple! :)
11342.14 In reply to 11342.11
Greetings!
I encountered a problem, when a polyline turns into a polycurve, the script doesn't work anymore
https://drive.google.com/file/d/1u2LwGowMSEeUYyLTR0SxRHH0jSVW0hO1/view?usp=sharing
Can this be solved?
11342.15 In reply to 11342.14
Hi Moi3dFan,
Yes, that's correct, the script is only designed to work on polylines which is what you requested.
Making it work on other types of input would need a pretty different process, it would not be a small change to the script.
I'm sorry I'm not able to do it at this time.
11342.16 In reply to 11342.15
It's ok, I found a way out by just disconnecting the corners I want and applying the script to them.
I sorry for the distraction, I hope everything is going well with your work
Show messages: All  1-9  10-16
