Reset view command or script
All  1-3  4-7
11336.4 In reply to 11336.3
Very useful.
Thank you.
Mik
11336.5
Good day.
Question...I have changed to shortcut to use the script which works perfectly.
but everytime I close and open Moi the shortcut is changed back to an old command?
I use c - chamfer and changed chamfer to the new reset script.
Tnx.
11336.6 In reply to 11336.5
Hi Matadem, shortcuts are saved in the moi.ini file when MoI closes.
Do you possibly have multiple instances of MoI running when you set up the shortcut?
If so then close all but one instance, edit the keyboard shortcut and then close the last instance so that it can write out settings to the moi.ini file.
If that isn't it then have you possibly set the moi.ini file to be read only?
11336.7 In reply to 11336.5
You may have to resave your open template file so it saves it
Show messages: All  1-3  4-7
