Filleting the whole corner?
All  1  2-9
11331.2 In reply to 11331.1
Choose constant distance as the type of fillet you want
But with that said, this expectation will run into various issues in other situations
11331.3 In reply to 11331.1
10 x 10 is not a rectangle, it's a square! :)
11331.4 In reply to 11331.2
Hm, I don't understand what Const Dist does, but when I enter 10 for my 10x10 "rectangle" :) it certainly does not fillet the whole corner.
11331.5 In reply to 11331.4
My Bad. I wasnt paying close enough attention.
So workaround would have to suffice.
you can extrude your rectangle out a bit and solid fillet it, then extract the curves you need
Or use the arc center point tool to draw in the full arc.
Just a workaround. I'll listen for Michael to discuss any details
Sorry about the original mislead.
11331.6 In reply to 11331.4
I had already made the first part, so I included it here to keep the warts!!!
11331.7 In reply to 11331.1
Hi Andre, I've been looking at this and I think I can get it fixed up, know more tomorrow.
11331.8 In reply to 11331.3
Squares are rectangles, but only some rectangles are squares.
11331.9 In reply to 11331.1
Hi Andre,
> I know, fillets are a finicky thing, but this seems so simple that maybe it can be fixed?
> Create a rectangle with known dimensions, for example 10 x 10 mm. Try to fillet one
> corner completely, i.e. set the fillet radius to 10. -> Calculation failed
This is fixed for the next v5 beta.
Show messages: All  1  2-9
