Smooth transition how would you do this?
All  1-2  3-6
11326.3
Thank you!
you can also press Tab and write your script's name!
Here that will be RebuildSurface with any hight letters but without spaces!!!
11326.5 In reply to 11326.4
Could u show us how it's done using RebuildSurface ? but, could you please use Matadem 3dm file?
11326.6 In reply to 11326.5
Don't forget that for use Rebuild Surface for any process or purpose...
Surface must have 3 or 4 edges!
So...a beginning can be to trim the surface by an isocurve
The game is to find the more tricky trimming!
But the left part has always 5 edges so...etc...
2 horizontal curves because the original curves edges for any reason has a trimmed point !
It's not a trivial process...and the Rebuild surface itself has some tricky parts & possibilities! :)
You must have 15 years of car modeling behind you like zarkow for find the good triming to apply inside MOi! :)
Best is to try to use only classic Nurbs and not patch for make imaginative cars!
Field is yet some large for play with them! :)
Look at the Nixus by Cristobal Vila... (video 16 years old) ;)
look this post! ;)
http://moi3d.com/forum/index.php?webtag=MOI&msg=10570.7
EDITED: 16 Jan 2024 by PILOU
Show messages: All  1-2  3-6
