MOI Script Pipe2Thickness evolve into TUBE TOOLKIT
 1-10  …  31-50  51-70  71-90  91-93
11314.71
Hi WN,
thank you for your suggestions.
The problem is there are so many standard sections & the concat node is limited to 6 inputs.
I have made a manual input nod file as Pilou suggested for now please have a look.
I have also modified the positioning of the profile in the 'Y' axis as just moving in the 'X' did not clear the bounding box
when a path is just a straight line on the 'Y' if that makes sense.
This applies to the Pipe tool as well so will update my post.
have made the rotation +- 180 and now a manual input for profile sizes.
Many thanks to you both.
Barry
EDITED: 2 Feb 2024 by BARRY-H
11314.72 In reply to 11314.71
Cool new version
For the next :)
General concept of the sweep with one rail!
But take only case of the profil is touching the rail else that will be headache of the Profil orientation!!!
EDITED: 31 Jan 2024 by PILOU
11314.73
WOW! from a small request so much function, so many tools to play with and so many possible directions. Off to play....
many thanks to all who have input keeping MOI the sharpest pen in the pack.
All the best Alex.
11314.74
have updated the pipe tool with a minor bug fix.
Also have modified the Sections nod file.
Have removed the gate selection system and replaced with a slider.
A fillet adjustment slider as also been added.
Barry
11314.75
Hi All just getting some test files ready to put through the 4 axis pipe bender - and for some reason I cant shell this rebuilt curve from a series of arcs I have checked continuity and all seems to be OK. Any ideas would be helpful.
11314.76 In reply to 11314.75
Hi Alex, I simplified the rail by using the v5 merge command on it so that it's all one segment instead of in multiple segments and if you sweep this version and select the end faces it looks like it's shelling ok then.
11314.77
Thanks Michael for speedy reply with the merge command it looks like the ARC info is lost - I need to retain this so the tube bender has the curve continuity to calculate the bends for each sequence along the part hope that makes sense.
11314.78 In reply to 11314.77
Hi Alex,
try boolean inner from outer rather than shell.
Barry
11314.79 In reply to 11314.77
Or another way is sweep the outer circle with "Cap ends" turned off, sweep inner circle also with "Cap ends" off then make end caps by selecting inner and outer circle together and use the Construct > Planar command, then select the 2 sweeps and 2 end caps and use Edit > Join to glue them together.
11314.80
Hi all.
I ran into this problem: the "shell" command does not process all values, in this case from 0 to 1, and then 3 and 5 and some intermediate values.
Maybe it's just me?
Moi v5 beta nov 29 2023
Size: 128.5 KB, Downloaded: 36 times, Dimensions: 1361x714px
11314.81 In reply to 11314.80
Hi WN, currently shell in MOI is just not very reliable, it should get a big boost though once I switch it to be handled by ACIS.
11314.82 In reply to 11314.81
Hi Michael, I see now, thanks.
There is another problem there, perhaps it is also related to this command, the display of surfaces and bodies disappears.
But if you apply the "separate" command, then visibility is restored.
The file is the same.
11314.83 In reply to 11314.82
Hi WN, the surface visibility problem was a bug in the Nov-29-2023 v5 beta, it should be fixed in the Dec-1-2023 v5 beta so please update to that version: https://moi3d.com/beta.htm .
Thanks, - Michael
11314.84
Thanks all for the workarounds - I have been converting a few of these type of curves in preparation for bending most shell fine in MOI. Have read the above comments - I am trying to work out what causes the geometry from not working I checked direction in Rhino and the PIPE command in Rhino also and the same curve came up fine. Any ideas welcome.
11314.85 In reply to 11314.84
Hi Alex,
Do you mean not working for Shell? Or something else?
11314.86
Thanks for reply YEP the shelling try to work out why MOI is having problems shelling without a manual construction of the shape.
regards
Alex.
11314.87 In reply to 11314.86
Hi Alex, shelling is probably thinking that some of the edges are sharp and that they need to be extended and intersected which it does not do a good job of.
This should get a lot better when I'm able to get shelling handled by ACIS but for now you would need to generate the shelling manually as described above.
Do you need more details on how to do that part?
11314.88
Thanks Michael that probably makes sense - the work around also and have rhino and solidworks as backups so all good for the moment. So far in the files I have been generating in MOI have been shelling AOK its the first one that failed will put some of the files through the tube bending software and see how they behave will post real world transitions of some of these shapes as they happen.
regards
Alex.
11314.89
There seems an issue with the curve as when you sweep the circle it produces 2 objects not 1.
This corresponds to a end point on the curve.
Removing this point allows the sweep to generate a single object as it should.
Barry
11314.90 In reply to 11314.89
Hi Barry.
The problem is that there is no tangent between them.
This can be fixed roughly by running the "union" command or by deleting one of the segments, then use the "sweep" command to connect the ends, after applying the "separate" command to the curve. Or make the arcs tangent.
You cannot delete a point, because you will get a nurbs curve, and here you need lines and arcs. Everything else, that is, all kinds of splines, nurbs curves, and so on, are not suitable for this. Most CNC machine control racks allow you to import DXF files, but they should contain only lines and arcs, since initially the structure of the control program is the movement of machine organs along straight lines, which are G1 X...Y...Z... and arcs G2 X...Y...Z... i...j...k... and G3 are the same but in a different direction.
EDITED: 21 Feb 2024 by WN
Show messages:  1-10  11-30  31-50  51-70  71-90  91-93
