MOI Script Pipe2Thickness evolve into TUBE TOOLKIT
 1-4  5-24  25-44  45-64  …  85-93
11314.5 In reply to 11314.1
Hi Alex,
you can use the nodeditor to achieve what you want.
Attached is a nod file that does it.
Give it a try.
Barry
Edit.
See later post for latest node.
EDITED: 18 Jan 2024 by BARRY-H
Size: 161.6 KB, Downloaded: 59 times, Dimensions: 800x631px
11314.6
Thanks Barry, appreciated will have a play with it.
Will get back to you
regards
Alex.
11314.7
Hi Barry, Had a play with it I get to select the curve but geometry doesnt build I am running editor 1.1 is this the correct current version? from the wiki seems I am up to date. Also one comment on the node is with the script you can select an entire group of curves and they all populate at once - this is how weldments on Solidworks and other programs work in a similar fashion could this be possible also - selecting a group of curves.
11314.8 In reply to 11314.7
EDITED: 29 Jan 2024 by BARRY-H
11314.9 In reply to 11314.8
Hi Barry,
Where is the Pipe Macro? (from where can I get it?)
-Psygorn
11314.10 In reply to 11314.9
Hi Drillbit,
The Pipe Macro is just a container that holds the nodes.
Right click on it and open you will see the node setup I used.
Macro’s are away of tiding node circuits.
Barry
11314.11 In reply to 11314.10
Hi Barry-H,
I meant when I load your node into my nodeeditor Macro node shows a red square! (I believe it means something is missing! am I right?) and I cannot run the node!
I even drew a curve and named it (because I thought I should select a curve. Yet, it didn't work!
Could you please help me out here! may be you know what is missing!
Edit: inside Macro the displays are all red!
Best,
Psygorn/Drillbit
11314.12 In reply to 11314.11
Hi Drillbit,
I coloured the macro red but if its not possible to run it means a node is not recognised.
Having looked I think its the display nodes inside the macro so just wire them out or
I have updated the Pipe Tool nod file with them removed so try that first.
( r2d2 updated the display node and that's what I used)
Barry
EDITED: 22 Jan 2024 by BARRY-H
11314.13 In reply to 11314.11
Hi Psygorn.
Show me a screenshot of the screen.
If the system does not have the necessary nodes, the editor runs in limited mode, some buttons are blocked.
I have attached the first version of Barry's file, there are only other parameters of the regulators.
If the computer is weak, use the editor in step mode.
https://disk.yandex.ru/d/eyHL_9IQsyIkDw
https://disk.yandex.ru/d/6oFC05cFgf5snA
Size: 55.6 KB, Downloaded: 71 times, Dimensions: 925x605px
Size: 250 KB, Downloaded: 84 times, Dimensions: 1358x722px
11314.14 In reply to 11314.12
Hi Barry-H,
The Run button is not active yet!
Note: maybe I am doing something wrong so, could u please describe how properly I should use the node? I mean I should draw a curve as path (and if it doesn't have sharp corners I can leave Fillet at 0) then I select the curve and update)
am I doing it right?
Maybe with a basic tutorial my issue would be resolved!
- Psygorn
11314.15 In reply to 11314.13
Hi WN,
- Psygorn
11314.16 In reply to 11314.15
Hi Psygorn.
My screenshot shows how the non-working node is displayed. In the title bar of the window, the node name and the small square are red.
There is no such node or it has been changed. Therefore, you need to find out which nodes are not working.
Size: 281.8 KB, Downloaded: 57 times, Dimensions: 1358x722px
11314.17 In reply to 11314.16
For avoid all that it's a good thing that the creator of any node gives its entiere NodeEditor folder !
It's something like one mega so not a big deal!
You have just to rename before your curent one as you want as temporary folder! :)
There is maybe only less 20 creators of nodes so... ;)
EDITED: 23 Jan 2024 by PILOU
11314.18 In reply to 11314.15
Hi Drillbit,
are you using the nodeditor I have posted ?
Post a screenshot of the open macro this would help.
Barry
Method added see gif below.
EDITED: 23 Jan 2024 by BARRY-H
Size: 137.4 KB, Downloaded: 57 times, Dimensions: 800x533px
11314.19 In reply to 11314.18
Hi Barry-H,
No, I am using my own tuned nodeeditor. If I can find out what is missing in my nodeeditor I can add that and I guess things will be fine!
And, thanks for the attached image, but I believe I did the very same thing yet no results! (the run button is not active!)
Here is the insde of the Macro
-Psygorn
EDITED: 23 Jan 2024 by DRILLBIT
11314.20 In reply to 11314.19
Hi Drillbit,
have you opened the macro yet ?
Barry
11314.21 In reply to 11314.20
Yes, I edited my previous post! Please take a look.
11314.22 In reply to 11314.20
Hi Drillbit,
it's as I thought its the display node.(In between Fillet to compare)
Just wire straight to the compare node and delete the display node.
Barry
11314.23 In reply to 11314.22
Hi Barry-H,
Now the run button is active but it does nothing! I open the nodeeditor and then select the curvepath and update Mulit Select
The Curve path turns into dashed line then I hit apply it disappears! And by closing the nodeeditor the selected curve path appears again.
Needless to say I tweak other nodes but nothing happens. and Even MOI Crashed!
- Psygorn
11314.24 In reply to 11314.23
Hi Drillbit,
so after running you get nothing ?
Open nodeditor before selecting any objects for some reason if you select and then open nodeditor it locks up.
It maybe that get by name is a better option but that's one path at a time.
Will investigate and let you know.
Barry
Show messages:  1-4  5-24  25-44  45-64  65-84  85-93
