MOI Script Pipe2Thickness evolve into TUBE TOOLKIT
 1-7  8-27  28-47  48-67  68-87  88-93
11314.28
Such settings cause a long and tedious wait.
11314.29 In reply to 11314.28
Hi WN,
the issue with the settings you used is the fillet needs to be larger than half box width.
I will add a mini fillet restriction to avoid this.
Barry
11314.30
EDITED: 29 Jan 2024 by BARRY-H
11314.31 In reply to 11314.29
Hi Barry.
Thanks!
11314.32 In reply to 11314.30
Hi Barry,
I think now Rev Switch node doesn't work! (what is it or where should I find it?)
- Psygorn
11314.33 In reply to 11314.32
Hi Psygorn.
It can be thrown out and switched manually, it will work the same way.
11314.34 In reply to 11314.32
Hi Drillbit,
a link to where the Switchrevers is in my previous post.
It allows the ability to switch path curve to pipe or box.
I think this way only the required part is calculated.
Anyway give it a try.
Barry
11314.35 In reply to 11314.8
Barry-H,
Thank you for posting the updated nodeeditor zip.
I have been missing the Updated Display node for many months, due to having an old r2d3.js file in the node > extensions folder, (with nodes showing up in nodeeditor canvas under infos.)
The "newer" r2d3.js file shows a date of 3/9/23, and has 736 code lines.
This r2d3js file creates a new menu entry in nodeeditor canvas, (r2d3), with 9 node entries (currently).
EDITED: 24 Jan 2024 by BEMFARMER
11314.36 In reply to 11314.20
Hi Barry,
Yes, Pipe Macro & Box Macro both look fine to me!
RevSwitch on the other hand, does nothing (even when I double click it)
-Psygorn
11314.37 In reply to 11314.36
Hi Drillbit,
Switchrevers node diverts the path to pipe or box whichever one you want to produce.
Did you download it from the link I posted ?
Barry
11314.38
Hi Barry,
Many thanks for posting your NODE Pack - all working great really powerful node - what is the process of selecting multiple control paths to form the group of multiple selection?
Alex.
11314.39 In reply to 11314.38
Hi Alex,
I just select all paths then index through them with the knob selecting pipe or box with the switch and applying.
When trying to do the Boolean operation on all of them at same time caused problems.
Barry
Update;
you can try bypassing the index select and plugin directly into the RevSwitch.
Just tried with 100 curves and it took 20 sec for pipe and 30 sec for box.
Any problems you can revert to index select.
EDITED: 27 Jan 2024 by BARRY-H
11314.40 In reply to 11314.37
Hi Barry,
I believe I did (if I did not mess anything up!) However, it still doesn't work! you can see my path (Dashed curve) It has a name "Path" and I did not select it before opening Nodeeditor.
11314.41 In reply to 11314.40
Hi Drillbit,
From your photo the switch is set to multi paths so you will get nothing as you have selected get by name.
Make sure your pipe size is not to big for your path.
If your still having trouble post your path and I will have a look.
Barry
11314.42 In reply to 11314.41
Hi Barry,
Everything works fine now :-)
Tanx!
Hello
I have 2 curves selected (multi select node) ...works fine but seems i can't keep both of them in the same time?
What i miss ?
i used this Barry node http://moi3d.com/forum/index.php?webtag=MOI&msg=11314.30
EDITED: 28 Jan 2024 by PILOU
Another thing :)
At the end of a node session I must use this script for select objects generated existing on the screen!
script: var objs = moi.geometryDatabase.getObjects(); for ( var i = 0; i < objs.length; ++i ) { var obj = objs.item(i); obj.setHitTest( true ); }
is that the same for you ?
I have maybe not the last version of nodeeditor!
Nodeeditor 1.1 jms
Message 11314.45 deleted 28 Jan 2024 by WN
11314.46 In reply to 11314.45
so only the multi select to Swicht or other thing ?
Because i have only one object result but 2 curves selected..
11314.47 In reply to 11314.46
The multi select indexes thro your selections one at a time so you need to apply your selection before moving to the next selection.
This allows you to choose between pipe or box.
If your selections are all the same (pipe or box) give them the same name and select by get by name.
Hope that’s clear.
Barry
Show messages:  1-7  8-27  28-47  48-67  68-87  88-93
