MOI Script Pipe2Thickness evolve into TUBE TOOLKIT
 1  2-21  22-41  42-61  62-81  82-93
11314.22 In reply to 11314.20
Hi Drillbit,
it's as I thought its the display node.(In between Fillet to compare)
Just wire straight to the compare node and delete the display node.
Barry
11314.23 In reply to 11314.22
Hi Barry-H,
Now the run button is active but it does nothing! I open the nodeeditor and then select the curvepath and update Mulit Select
The Curve path turns into dashed line then I hit apply it disappears! And by closing the nodeeditor the selected curve path appears again.
Needless to say I tweak other nodes but nothing happens. and Even MOI Crashed!
- Psygorn
EDITED: 23 Jan 2024 by DRILLBIT
11314.24 In reply to 11314.23
Hi Drillbit,
so after running you get nothing ?
Open nodeditor before selecting any objects for some reason if you select and then open nodeditor it locks up.
It maybe that get by name is a better option but that's one path at a time.
Will investigate and let you know.
Barry
11314.25 In reply to 11314.23
@Psygorn - the crash could probably be mitigated by converting booleans to use processing in moi_commandprocessor.exe instead of in-process.
Like MO describes for fillets here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=9581.348
11314.26 In reply to 11314.25
Thank you Michael,
as always!
- Psygorn
11314.27 In reply to 11314.26
Hi Drillbit,
multi select causes problems so change select method to select by name its more stable.
Make sure when opening Nodeditor no paths are selected for some reason this causes a lockup.
If there are close Nodeditor deselect and open Nodeditor again.
Barry
11314.28
Such settings cause a long and tedious wait.
11314.29 In reply to 11314.28
Hi WN,
the issue with the settings you used is the fillet needs to be larger than half box width.
I will add a mini fillet restriction to avoid this.
Barry
11314.30
EDITED: 29 Jan 2024 by BARRY-H
11314.31 In reply to 11314.29
Hi Barry.
Thanks!
11314.32 In reply to 11314.30
Hi Barry,
I think now Rev Switch node doesn't work! (what is it or where should I find it?)
- Psygorn
11314.33 In reply to 11314.32
Hi Psygorn.
It can be thrown out and switched manually, it will work the same way.
11314.34 In reply to 11314.32
Hi Drillbit,
a link to where the Switchrevers is in my previous post.
It allows the ability to switch path curve to pipe or box.
I think this way only the required part is calculated.
Anyway give it a try.
Barry
11314.35 In reply to 11314.8
Barry-H,
Thank you for posting the updated nodeeditor zip.
I have been missing the Updated Display node for many months, due to having an old r2d3.js file in the node > extensions folder, (with nodes showing up in nodeeditor canvas under infos.)
The "newer" r2d3.js file shows a date of 3/9/23, and has 736 code lines.
This r2d3js file creates a new menu entry in nodeeditor canvas, (r2d3), with 9 node entries (currently).
EDITED: 24 Jan 2024 by BEMFARMER
11314.36 In reply to 11314.20
Hi Barry,
Yes, Pipe Macro & Box Macro both look fine to me!
RevSwitch on the other hand, does nothing (even when I double click it)
-Psygorn
11314.37 In reply to 11314.36
Hi Drillbit,
Switchrevers node diverts the path to pipe or box whichever one you want to produce.
Did you download it from the link I posted ?
Barry
11314.38
Hi Barry,
Many thanks for posting your NODE Pack - all working great really powerful node - what is the process of selecting multiple control paths to form the group of multiple selection?
Alex.
11314.39 In reply to 11314.38
Hi Alex,
I just select all paths then index through them with the knob selecting pipe or box with the switch and applying.
When trying to do the Boolean operation on all of them at same time caused problems.
Barry
Update;
you can try bypassing the index select and plugin directly into the RevSwitch.
Just tried with 100 curves and it took 20 sec for pipe and 30 sec for box.
Any problems you can revert to index select.
EDITED: 27 Jan 2024 by BARRY-H
11314.40 In reply to 11314.37
Hi Barry,
I believe I did (if I did not mess anything up!) However, it still doesn't work! you can see my path (Dashed curve) It has a name "Path" and I did not select it before opening Nodeeditor.
11314.41 In reply to 11314.40
Hi Drillbit,
From your photo the switch is set to multi paths so you will get nothing as you have selected get by name.
Make sure your pipe size is not to big for your path.
If your still having trouble post your path and I will have a look.
Barry
Show messages:  1  2-21  22-41  42-61  62-81  82-93
