wishes...
 1-10  11-30  31-42
1131.31 In reply to 1131.22
>>> Hi Pilou, normally that is called a "Variable radius fillet", and it should be something that I can add in. The geometry library that I'm using supports it, I just didn't have time to figure out a UI for it for version 1.
>>> I've added this to the wiki wishlist.
Variable radius fillet : I was planning to add this one on the wishlist. You've done it for me, thanks ! ;-))
Also for me :
- Text along a path (along a curve).
- When using the Array > Dir command, an extra option to choose the placement for the last arrayed object, not the offset point as this is currently the case.
1131.32 In reply to 1131.31
Hi Bernard, I added yours to the wiki as well.
1131.33 In reply to 1131.30
Hi Petr, re: automatic rebuild - I guess I could see a "Simplify" checkbox, and if you pushed it some additional UI would appear below it to ask for rebuild parameters... But it also may be better for me to dig into seeing if it is possible to create a more efficient result that is actually still within the regular tolerance.
Bending an object along a curve (and some "transformers")
A pipe maker
An "explode" function after a "boolean merging operation" for have each object on a 3D grid (that is impossible to make that by hand when objects are more than 10 ;)
Something for manage object (color (?), group(?), arborescence (?)...)
Complete history rebuilding
but with all that the V2 mabe will take a certain time to born ;)
EDITED: 19 Nov 2007 by PILOU
1131.35 In reply to 1131.34
Hopes in the feature :
1. Constant radius fillet
2. N-side surface patch
3. point control on surface and also add a point to the surface
4. input material properties, if not just input density to calculate weight of a part / assy
5. Generate BOM
6. Automatic dimension on 2D drawing
7. Selection tools : Select chain, select tangency, tangent propagation, etc.
8. Always agree if MoI can import 2D DWG file
9. Interference detection between object / part
10. Zebra strips
11. Curvature comb / check
Regards,
Lish
EDITED: 19 Nov 2007 by KHOLISH
1131.36 In reply to 1131.35
Hi Pilou, Hi Lish - these are also added to the wiki now.
Lish for your #1:
do you mean Variable radius fillet? Constant radius is the kind that MoI currently does.
1131.37 In reply to 1131.36
HI Michael.....
Sorry, I not have time back to MoI Forum yesterday.
>> Lish for your #1:
What I mean is constant width fillet.
Look at image & iges file attached :
Regards,
Lish
1131.38 In reply to 1131.37
Hi Lish thanks for explaining further, I've updated the wishlist page.
That type of fillet lets the radius of the curved fillet piece itself vary, to keep the distance between the fillet rails constant. The geometry library that I'm using has an option for this, so I should be able to add this at some point. But in some past tests it seemed a little less reliable than the constant radius fillet.
1131.39
shame on me I didn't notice about the curve text :s
I think I need to read something about history function 'cause I don't understand it.
by history I mean a list of actions an object received, sort of undo per object ?
1131.40 In reply to 1131.39
Hi Iwan,
I see - I do want to add more flexibility for undo in the future as well. That is a different sort of history.
What MoI usually calls history is something slightly different - when you create an object, MoI remembers the command that was used to create it, and it also remembers which other objects were inputs into that command. Like for example when you create an object by doing Extrude, MoI attaches some data to the extruded object that says something like "Created by Extrude, from curve with ID number 203".
Then later on if you edit that curve, MoI will go through objects that have history and see if any of them used that curve as an input. If it finds any, it will run that command again and update the result. So for instance if you edit that curve that the extrusion was built from, the extruded object will be erased, and then re-extruded with the new curve, so it will update.
Something for manage "curves generator" (hide /show) (rank) (?)...
EDITED: 26 Nov 2007 by PILOU
1131.42
instances?
Show messages:  1-10  11-30  31-42
