Script for quickly changing the theme from dark to light
All  1-4  5-8
11307.5 In reply to 11307.4
> Where can I see what classes are in Moi in order to write scripts myself?
There isn't currently official documentation for the scripting API, because that takes a lot of work.
However, there is some information here:
https://moi3d.com/wiki/Scripting
Also though if you want to script something that is in the regular UI, you can open up the UI files and find how it is accessed.
For example the UI control for changing the theme is in GeneralOptions.htm inside the UI folder in the install. If you look in there you can find that it sets it using moi.ui.theme = value;
11307.6 In reply to 11307.5
Thanks for the answer
11307.7 In reply to 11307.6
In addition to Michael's answer, here is another very worthwhile contribution toward API documentation for MoI:
https://moi3d.com/forum/index.php?webtag=MOI&msg=10857.36
--Larry
11307.8 In reply to 11307.7
thank you very much!!!!
Show messages: All  1-4  5-8
