Offset Node Issue
All  1-2  3-6
11298.3 In reply to 11298.2
Thanks Michael,
Regarding issue with differing behaviours of Construct2/Offset on Mac & PC: in response to your message above, MO did a test to see point generated for the process. He discovered 18 points (twice the number of objects) were generated, half these were slightly off-centre in each object, while the others were a long way from target object (such to be outside the image captured).
(Image provide by MO, Thanks MO for all your assistance with this issue)
I repeated the test, and found also that the generated points were similarly 2x number of objects, however the internal points all fall dead at the origin (0,0), rather than within each object, as in MO's test.
(I attached magenta spheres for greater clarity)
This difference would appear to account for differing behaviour of offset node, though I can't be sure if it is operating system related or just unique to my particular setup.
11298.4 In reply to 11298.3
Hi James, can you please post the script code that does the computation of the point?
Thanks, - Michael
11298.5 In reply to 11298.4
Thanks Michael,
The code for Offset node is attached: "offset.js"
I've also attached "main.js" because MO had suggested that the problem may in the difference
between 2 specific versions, for MacOS & for Windows.
I don't know enough about programming to direct you to particular lines in code.
Thanks for looking at this,
11298.6 In reply to 11298.5
Hi James, I'm not seeing any different code paths in there for Mac vs Windows.
Is the difference in behavior due to a custom construction plane being set on one system versus default world cplane in the other?
Because the plane returned by the offset factory's .getCurvePlane() function is used in the regular offset command as a plane for the pointpicker. When a custom cplane is set the origin of that plane returned by .getCurvePlane() will be the cplane's origin. It probably isn't good to use the pointpicker plane's origin point as a basis for an inside/outside point for offset. It may look like a good candidate because in some cases it's sort of a centroid point but not when there is a custom cplane set.
Instead of trying to generate a point inside a closed curve automatically it's probably better to give a point outside of everything's bounding box and then set a negative offset distance although that may not work properly until the next release when I can get this offset trim problem fixed.
Show messages: All  1-2  3-6
