Hi Peer,
> But, if I use the Text tool and adjust padding all that does is move the outline of
> the textbox relative to the text.
Yes this behavior of the text anchor point setting the position of the interior baseline of the text and then padding applied around that is inherited from Rhino and presumably AutoCAD.
There is not currently any way to avoid that behavior but I'll see if I can set up a flag to make it set the exterior corner instead.
