how to create this? twist flow?
11279.1
Good day
I am trying to make a shape...honestly I do not know if it is possible.
Attached a pic of what I am after the 2 shapes need to join other following the red lines...
I tried by making a rectangle solid, flow to bend ...but when I try twisting it does twist the whole shape sideways as well.
Any way to accomplish this?
Tnx!
Size: 34.8 KB, Downloaded: 65 times, Dimensions: 1022x655px
11279.2 In reply to 11279.1
Hi Matadem, the Blend command can be good for that.
First select the end faces:
And delete them, should look like this:
Then select a pair of edges:
And run the Construct > Blend command to make a blend surface between them:
Repeat for the other 3 pairs (one pair at a time so use the Blend command 4 separate times) and use Edit > Join to glue the surfaces together, see attached .3dm file.
Can be made in one pass! ;)
Same Blend function...
11279.4
got it!
Tnx!
