V5 Bug
All
1-2
3-13
alteschinken (DONOLDHAM)
28 Nov 2023 (3 of 13)
11254.3
Attached is a file which opens fine. However, when I select the tallest object, and try to MOVE it, it will crash every time.
Fish Hook Remover.3dm
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Michael Gibson
28 Nov 2023 (4 of 13)
11254.4
In reply to
11254.3
Hi alteschinken, what operating system are you running on?
Is there a crash dump file being generated?
I don't seem to be able to reproduce the crash over here.
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Charlie (BLARBLES)
28 Nov 2023 (5 of 13)
11254.5
If you drag to select then move it does crash but if you just click and move the tall object it does not crash.
There are a lot of extra geometry that are not part of the solid that may be causing the issue:
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Michael Gibson
28 Nov 2023 (6 of 13)
11254.6
In reply to
11254.5
Hi Charlie, do you get a crash dump file created?
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Michael Gibson
30 Nov 2023 (7 of 13)
11254.7
In reply to
11254.3
Ok, the crash is specific to new style Macs with the M1/M2 arm64 CPU. It's from a difference in behavior from Intel with how division by zero is handled. I'll have a fix for the next beta shortly.
Thanks, - Michael
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Michael Gibson
30 Nov 2023 (8 of 13)
11254.8
In reply to
11254.3
New v5 beta at
https://moi3d.com/beta.htm
should fix this crash.
Thanks, - Michael
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Charlie (BLARBLES)
30 Nov 2023 (9 of 13)
11254.9
The Nov beta does fix the crash issue.
alteschinken: Your file has some weird anomalies in it. Not sure how you ended up with the geometry in the red circle, but you cannot select them.
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Michael Gibson
30 Nov 2023 (10 of 13)
11254.10
In reply to
11254.9
There was a curve mirroring bug accidentally introduced in the Nov-29 v5 beta released yesterday.
So if you got that one please throw it out and get a new Nov-30 v5 beta instead at
Thanks, - Michael
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Moi3dFan
30 Nov 2023 (11 of 13)
11254.11
In reply to
11254.10
Wow! Michael, can you upload the new Nov-30 v5 beta to the Download section for OTOY subscribers?
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Michael Gibson
30 Nov 2023 (12 of 13)
11254.12
In reply to
11254.11
Hi Moi3dFan,
Yes I'll send it to them.
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Michael Gibson
1 Dec 2023 (13 of 13)
11254.13
There was another bug where objects that were hidden when initially loaded would get stuck in a wireframe display.
So there's another update and the current one is a Dec-1beta.
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Reply to All
All
1-2
3-13
