Script to generate viewport image question
All  1-2  3-5
11253.3
It works nice and fast...
a few more questions... can it be done with a white background? without any axis lines?
Can it be done with a transparent background? the reason for this if it is possible to put the 3d model in front of a picture to see what the end product would look like.
and last one can Moi export to pdf or an image format in all views at once ...or 2 views?
Thank you!
11253.4 In reply to 11253.3
Hi Matadem,
Yes, try the one on this message:
http://moi3d.com/forum/index.php?webtag=MOI&msg=9787.2
Sorry no the viewport display mechanism is only set up to display on a solid color background.
Not currently. However, there is a script you can set up which can generate the curves for all views and then you can export those:
http://moi3d.com/forum/index.php?webtag=MOI&msg=8041.1
11253.5
Now its even better :D
I set my perspective on the image I need in affinity...then send it to Moi to set the model the way I want with the picture...
Then snapshot and save...crop if I need it to...way faster.
Thanks!
Show messages: All  1-2  3-5
