Tapered fillet
11248.1
Hi!
I'm looking to make the circled portion a smaller radius than it's opposing side. How would I achieve that?
Also, are there any kind of Udemy courses on for this software? I really want to master it, but I haven't found a good, consistent series (there are good portions of series out there, however).
Thanks!
Size: 995.6 KB, Downloaded: 128 times, Dimensions: 1281x862px
We have many possibilities to do it.
The basic is filleting with use of Fillet set, but My advaice is to read documentation on this or consult a tuto because it's not easy when you do it for the first time.
You could use loft with 2 different profiles.
Sweep is also possible.
To find tutorials and courses, you can consult the ressource section in this website.
Many, are great for new users, some are more advanced.
Have a good modeling with MoI3D !
11248.3 In reply to 11248.1
Hi Brent,
There are a couple on Gumroad:
https://kotur.gumroad.com/l/vavRq
https://gumroad.com/l/fGqqS
11248.4 In reply to 11248.1
Hi Brendt, and for this part:
That can be done using a "variable radius fillet" which you can activate inside the Fillet command by expanding the "Fillet set" section in the Fillet options and clicking "New point set". That will allow you to pick a point and set a separate radius to be used for that point.
There is an example video on YouTube here:
http://www.youtube.com/watch?v=CemIL-wleOw
11248.5 In reply to 11248.4
Thank you Michael! Very helpful as always!
