Water tap surface challenge
All  1-2  3-20
A simple sweep 2 rails ?
11243.4 In reply to 11243.3
Thank you PILOU,
but that is not the problem, as i have already this surface.
The hard part is to close the gap to the cylinder surface.
11243.5 In reply to 11243.4
So after Gordon... (Network)
11243.6 In reply to 11243.1
Hi rhinouser141, usually it is best to make an initial structure that has sharp edges in it and use fillets to construct the transitions rather than trying to go around and fill in things "patch by patch".
11243.7 In reply to 11243.1
So more like this:
Basically you don't want to try to directly construct transition areas, you initially want broad simple surfaces and then have extended transitions between them that are then trimmed to make the final outline as opposed to drawing in all the final outlines at the start and trying to fill in surfaces directly between.
Like for example this area here, you don't want to try and fill that in with a surface that follows that boundary area directly, it should be a transition surface that is extended and trimmed to the final edges, not directly constructed to the final edges:
11243.8 In reply to 11243.7
Thank You very much Michael !!
11243.9 In reply to 11243.7
i downloaded your file and tried to fillet with the 3 corners, also with different options, but i does not work.
Best regards
Size: 98 KB, Downloaded: 72 times, Dimensions: 1688x836px
11243.10 In reply to 11243.9
Try with the v5 beta: https://moi3d.com/beta.htm .
11243.11 In reply to 11243.9
11243.12 In reply to 11243.10
Thanks ! Not it works.
Functions Fillet + Blend :)
EDITED: 16 Nov 2023 by PILOU
11243.14
Thank You All for your input. With your ideas and tactics i managed to create a model which i like.
Feel free to download the file if needed.
Rendered in Keyshot.
Best regards
Size: 227.5 KB, Downloaded: 85 times, Dimensions: 1280x1024px
Size: 212.7 KB, Downloaded: 65 times, Dimensions: 1280x1024px
Size: 389.3 KB, Downloaded: 71 times, Dimensions: 1280x1024px
11243.15 In reply to 11243.14
Congrats ! Well done !
Best regards
- Ken -
11243.16
Great achievement, compliments!
11243.17
The homework was handed in, I recorded a video of the modeling process, and the faucet was ready in no time. Share with you,
EDITED: 25 Nov 2023 by LONG
11243.18
In Plasticity
EDITED: 28 Nov 2023 by ZARKOW
11243.19 In reply to 11243.18
Zarkow, it is not appropriate to post advertisements for Plasticity coupon codes here.
Thanks, - Michael
11243.20 In reply to 11243.19
Yes, sorry, you're right, the commercial is my standard video description, I hadn't thought about that. I changed it to a OneDrive link without ads. Today I like to use both tools in combination.
Show messages: All  1-2  3-20
