CONVERT LINE TO DASH
 1-4  5-24  25-42
11239.5
Thanks Pilou I have downloaded but am I missing something in its use selecting curve then running script but nothing happens is there a more current version?
PatternSelection.v.0.3.2014.02.20.
11239.6 In reply to 11239.5
Hi Alex, so I guess PatternSelection is not what you need - it can only select stuff if it has already been sliced up, it does not do any slicing itself.
But instead try this attached DashCurve script that I cooked up to dash-ify a curve:
EDIT: updated DashCurve.js script to fix bug when click selecting curves.
EDITED: 5 Nov 2023 by MICHAEL GIBSON
11239.7
so perfect - job done
11239.8
Looks great Alex, doing some papercraft previously and origami they sometimes use different dash patterns for valley or mountain folds so the user knows which direction the fold goes
11239.9 In reply to 11239.8
Nice one Michael. Alex, how did you do the unfold?
JFS
11239.10 In reply to 11239.6
DashCurve is a very cool script.
It looks like Blend could un-dash-ify some dash curves, if proximity, and start/end points could be identified?
English learned by osmosis, not taught...
Had a little fun doing Google search of "adding ify to a word":
"What does the morpheme ify mean?
-ify which allows us to turn an adjective into a verb meaning make something become something (simplify, amplify)"
EDITED: 2 Nov 2023 by BEMFARMER
About the original post of the Max Smirnov Selection Pattern Selection ! ;)
Place a point on a curve and propagate it using the Array on Curve
Cut the curve by these points
Delete the points
Select the curves
Call the Plugin: _PatternSelection
You can add 0,1,etc... and + and - for have any drawing of Dash lines! ;)
But you right the file was not accessible ... Replaced my false link and file ! ;)
https://moiscript.weebly.com/scripts-de-max-smirnov.html
You can type any key not only number or sign!
EDITED: 2 Nov 2023 by PILOU
11239.12
Hello PAQUICINNO
I built the shape in RHINO SUBD but can be built in other poly programs (SUBD did a better job in controlling minimal faces and clean joins) - I then convert to NURBS and use the RHINO COMMAND UNROLL DEVELOPABLE SURFACE to flatten. Pretty easy work flow I then manually split to fit on a sheet I have cut one on a plotter to test all worked perfectly.
Michael - many thanks for the script I am working this up to cut one out in metal would it be possible to add width to the dash in the script as an extra input or leave blank for general use - the straight slot works for paper folding but in metal lets say the metal is 2mm thick to hand fold it would require a slot width of about 2.5 to allow for bending clearances this way this sort of shape can be hand bent in metal then the major joins welded together.
11239.13 In reply to 11239.12
Hi Alex,
Actually I had thought about putting that in, but it's kind of complicated for it to handle dashes that go around a sharp corner.
But you can easily add width like that by selecting the dashes and using Construct > Offset with "Both sides" and "Cap ends" enabled:
11239.14
The best way I found to unfold some items that I make in metal or cardboard is a program called pepkura > https://tamasoft.co.jp/pepakura_designer/
You get all the fold lines, tabs to glue and even animation how to fold and unfold...well worth the money.
11239.15 In reply to 11239.13
hi Michael
Thanks for this script.
Christian
EDITED: 6 Nov 2023 by CHRI
11239.16 In reply to 11239.15
Why not select the 2 curves and run the script ?
French version! ;)
https://moiscript.weebly.com/courbes-en-tirets.html
The FatLines script can widen the dashes...
11239.18
Thanks Michael,
Great Script
www.jameselliott.co.uk
11239.19
Yep keep it simple all the above suggestions work why mesh with something when it does what it says.
Keep in the MOI wavelength.
many thanks all
Alex.
11239.20 In reply to 11239.6
Strangely the plugin works randomly, it is unstable. Sometimes the plugin works on one line then no longer works on another almost identical one.
On other tests, the line on which I want to apply it disappears, when I exit the function it reappears but not always.
- Zooen
11239.21 In reply to 11239.20
Hi Zooen, can you please post the .3dm file with the curves that don't work?
11239.22
2MM Aluminium 15mm DASH ( SLOT ) 5mm GAP ( TAB) Hand bent Origami extreme test went together really well.
Thanks Michael a great tool.
11239.23 In reply to 11239.22
Cool work Alex! - Michael
11239.24
Thank you, Michael.
Show messages:  1-4  5-24  25-42
