CONVERT LINE TO DASH
 1-15  16-35  36-42
11239.36 In reply to 11239.34
@MO - thanks I think you have the bug diagnosed there, when the curve is click selected then Flow flips its direction but the Trim processing part of the script is only looking for a trim fragment that is in the natural curve direction.
I should be able to tune up the Trim logic later today.
Thanks for figuring out the bug depended on the click selection location that made it seem kind of random.
I'll also see about adding in a trim function on curves so that can be used in the future instead of the trim factory which is kind of awkward to script.
11239.37 In reply to 11239.36
Cool, Thanks
11239.38 In reply to 11239.37
Ok, script above (http://moi3d.com/forum/index.php?webtag=MOI&msg=11239.6) has been updated to fix the bug when click selecting.
11239.39 In reply to 11239.32
> Maybe when selecting a closed curve, selected point/direction does not matter?
Yup, with the flow command if you select a base or target curve by a click it will use the side closest to where you clicked it as the beginning side of the flow but that is only for open curves and not closed curves.
The DashCurve script was inheriting that since it uses flow internally, but when it was flipped that was messing up the trimming part of the script.
Should be fixed now.
11239.40 In reply to 11239.39
Thank you Michael :-)
11239.41 In reply to 11239.38
Thanks Michael (and thanks MO for the bug analysis),
What a time and quality saver for drawing production.
I also hope that the integration of ordinate dimensioning will be included in the final V5.
The more I use MoI3D and the more I explore its possibilities, the more I find this software brilliant.
- Zooen
11239.42 In reply to 11239.41
Hi Zooen,
Sorry no that isn't planned currently.
Show messages:  1-15  16-35  36-42
