CONVERT LINE TO DASH
 1-18  19-38  39-42
11239.19
Yep keep it simple all the above suggestions work why mesh with something when it does what it says.
Keep in the MOI wavelength.
many thanks all
Alex.
11239.20 In reply to 11239.6
Strangely the plugin works randomly, it is unstable. Sometimes the plugin works on one line then no longer works on another almost identical one.
On other tests, the line on which I want to apply it disappears, when I exit the function it reappears but not always.
- Zooen
11239.21 In reply to 11239.20
Hi Zooen, can you please post the .3dm file with the curves that don't work?
11239.22
2MM Aluminium 15mm DASH ( SLOT ) 5mm GAP ( TAB) Hand bent Origami extreme test went together really well.
Thanks Michael a great tool.
11239.23 In reply to 11239.22
Cool work Alex! - Michael
11239.24
Thank you, Michael.
11239.25 In reply to 11239.21
Michael >Hi Zooen, can you please post the .3dm file with the curves that don't work?
Test-Dashcurve.3dm
- Zooen
EDITED: 18 Aug 2024 by ZOOEN
11239.26 In reply to 11239.22
Hi Alex,
Awesome stuff!
This is a resource Michael provided a few years back.
Your work reminded me of it. Its cool because it allows you to design “cut paths” for curved surfaces also. So little half moon slices to roll up a flat sheet into a curve.
Thought you would like to get a look if you hadn’t already heard or seen about it.
http://laminadesign.com/index.html
I have a license but we never got the machine that would facilitate cutting paths well…
Message 11239.27 deleted 5 Nov 2023 by BEMFARMER
11239.28 In reply to 11239.26
11239.29
Thanks Burrman - I had crossed past Lamina years ago but didnt really have the way to cut those shapes outside of laser - I have just setup a CNC Plasma really economical setup single phase and just with an air compressor the cut quality is amazing. Ill have a play with lamina I have some 1mm aluminium should be soft enough to get it to bend into non planar shapes.
Here is a trial shape in 3mm Mild Steel 20mm Slot 3mm Tabs just like bending cardboard. I model the shapes with unthickened surfaces and so far the material thickness has really not effected the shape coming together I guess that maybe a problem in higher gauge materials.
11239.30 In reply to 11239.29
Wow! I really like this last one!!!
Definitely look back at lamina too. The process has a “material thickness calculation.
Anyway, don't be shy about posting your results. That last one is beautiful!
Envious
Message 11239.31 deleted 5 Nov 2023 by BEMFARMER
11239.32 In reply to 11239.31
Deleted several posts, as observations were weird symptom(s), not cause(s).
It looks like I was selecting different points on a curve, on different trials.
Maybe when selecting a closed curve, selected point/direction does not matter?
EDITED: 5 Nov 2023 by BEMFARMER
Message 11239.33 deleted 5 Nov 2023 by BEMFARMER
11239.34
Hi
Thanks Michael, Another cool plugin.
I had the same problem "Zooen" mentioned. And I guess it's something to do with the "flow" factory?
When I select one of the "Zooen's" attached curves by "clicking", the problem occurs.
The results will change based on the selected position. (Start or end of the curve)
The problem will solve if you "drag-select" the curve.
Message 11239.35 deleted 5 Nov 2023 by BEMFARMER
11239.36 In reply to 11239.34
@MO - thanks I think you have the bug diagnosed there, when the curve is click selected then Flow flips its direction but the Trim processing part of the script is only looking for a trim fragment that is in the natural curve direction.
I should be able to tune up the Trim logic later today.
Thanks for figuring out the bug depended on the click selection location that made it seem kind of random.
I'll also see about adding in a trim function on curves so that can be used in the future instead of the trim factory which is kind of awkward to script.
11239.37 In reply to 11239.36
Cool, Thanks
11239.38 In reply to 11239.37
Ok, script above (http://moi3d.com/forum/index.php?webtag=MOI&msg=11239.6) has been updated to fix the bug when click selecting.
Show messages:  1-18  19-38  39-42
