How To Make This Object
All  1-2  3-6
Is This you wanted ?
If Yes, then use this process
- Build a box
- offset on edges of each dimensions (here the orange rectangles)
- Boolean Diff the box with the 3 dimensions rectangles
If you want only all the lines as an object, you could use a group
Select all your lines and create a group.
Selecting a line will select all the lines in the group.
But group possibilities are only in version 5.
11232.5 In reply to 11232.1
Hi Frederick, curves in MoI are path-like objects - you can't have a single curve that branches like that with 3 lines coming out from a single point.
But like Phiro writes above if you want it to select as one unit you can do that in MoI v5 by making it into a group. You use the "Group" command which is off of the "Objects" section in the scene browser.
11232.6
Thanks to everyone.
Michael explained why the "wire frame" didn't work for me.
And I was provided with two solutions.
Thanks again.
Frederick
Show messages: All  1-2  3-6
