How To Make This Object
11232.1
See attached.
I gave up on what I wanted to do and drew this using 4 rectangles.
Visually it is what I want but I would like it to be one object.
Is that possible? If so, how do I do it?
I tried just using lines. I was able to join the 4 lines at the top and bottom to make two rectangles but I could not then join the vertical lines to the two rectangles.
While I wait for an answer I am going to return to feeling stupid.
Thanks much.
Frederick
EDITED: 26 Mar 2025 by FCWILT
11232.2 In reply to 11232.1
I do not think that the line "wireframes" can be joined together, with vertices with 3 lines connected(?).
As a rectangular 3D box Solid, the edges are present.
Wireframe view scripts link:
http://kyticka.webzdarma.cz/3d/moi/#RandomizeStyleColors
Edge Tubes could be joined...
Is This you wanted ?
If Yes, then use this process
- Build a box
- offset on edges of each dimensions (here the orange rectangles)
- Boolean Diff the box with the 3 dimensions rectangles
If you want only all the lines as an object, you could use a group
Select all your lines and create a group.
Selecting a line will select all the lines in the group.
But group possibilities are only in version 5.
11232.5 In reply to 11232.1
Hi Frederick, curves in MoI are path-like objects - you can't have a single curve that branches like that with 3 lines coming out from a single point.
But like Phiro writes above if you want it to select as one unit you can do that in MoI v5 by making it into a group. You use the "Group" command which is off of the "Objects" section in the scene browser.
11232.6
Thanks to everyone.
Michael explained why the "wire frame" didn't work for me.
And I was provided with two solutions.
Thanks again.
Frederick
