SELECT CONTENTS by boundary
All  1-4  5-11
11230.5 In reply to 11230.4
Hi Alex, please try this attached version, it should work on both solids and curves.
Select the boundary curves first before running it.
EDIT: Updated to not try to process hidden/locked objects.
EDITED: 23 Oct 2023 by MICHAEL GIBSON
11230.6 In reply to 11230.5
Seems don't working for curves !
Works fine for solids & planes surfaces!
11230.7 In reply to 11230.5
Thank you Michael. Another useful script.
It works nicely.
I studied your script. As a thought, what if we use the sketch tool as outline?
I think you can change this to add a pseudo lasso selection tool.
Or possibly circle and polygon selection tools?
something like this:
if ( outlines.length == 0 )
save current CPlane
getViewportUnderMouse
if(viewport == 3D) : Align CPlane with 3D view
start "sketch" factory.
Ask the user to draw a curve
when sketch finished : if (curve is open) : close it
use this curve as "Outline"
outlines = "sketch" factory result
continue ...
when finished or canceled : restore CPlane
11230.8 In reply to 11230.6
It's working ok for curves for me, can you please post the .3dm file with the curves that are not working for you?
11230.9 In reply to 11230.6
Hi Pilou, thanks for sending me the file. It’s not working there because one of the curves is not planar. For it to work all the curves must be in the same plane.
11230.10 In reply to 11230.9
ok! :)
11230.11
once again - AMAZING
many thanks Michael
Show messages: All  1-4  5-11
